FS: HRE 590R satin black for 997 WB
I have listed a set of HRE 590R satin black with polished lip in the FS section.
https://www.6speedonline.com/forums/...s-springs.html
HRE and alot of other wheel companies do not disclose the offsets.
they are aggressive widebody offsets, so they will not fit the narrowbody for sure.
someone told me they might fit a cayman but i have no idea
well, the most aggressive offset i have seen on a widebody is the techart formula and those are et40, so they should fit with no problem if you are going with an offset of 37.
If you are ready to buy, I will obviously call wheelenhancement tommorrow to verify.
ok boostedtwin, i got the info.
sounds like good news.
there was an initial error in the size of the rear wheel it is no 11 but 11.5
The rears are 11.5 x 19 with an offset of 42mm. The front ones are 8.5 x 19 with an offset of 50mm.
so if you are running an offset of 37mm on a 11in wheel
than this should be similar since 1in=25.4mm, then 1/2in-=12.7mm
that is 6.35mm on each side so with an offset of 42mm, you will be around 36mm final offset.
FYI the guy at wheelenhancement said it would be too aggressive for a cayman, but if you are running 37mm i dont see how a 36mm offset would be a problem...
these wont fit narrowbody.
But I am considering selling my champion rg19, same setup except 1 piece, satin black center with polished lip.
Lemme know if you are interested.
if i dont sell them, I am about to unmount them to have them redone in a different color.
awdbiturbo1
02-18-2016 10:24 AM
Vellano Wheels
Nissan GTR
08-19-2015 06:43 PM
