Wheels/Tires
Tire mounting lube needs to dry?
Old 02-20-2009 | 11:52 AM
DFW911T's Avatar
DFW911T is infamous around these partsDFW911T is infamous around these parts
How long does it take for the lube used during installation to dry (cure?) on the rim?
Since they're 30's, the installer said to wait 24 hours until I beat on it. He commented that it would take that long for the lube to dry out and then the possibility of the wheel spinning inside the tire would be lessened.
True or false?
Old 02-20-2009 | 06:38 PM
DNugget991GT3's Avatar
when the tire guy told you this, were there other men around him ?
men with beer bellies and beards ?
i think he did it to mess with you, or he is an idiot...
or damon will respond to this thread, and say he's right, thus making me look like a *****...
im going with the latter.... the lube doesnt need to dry
Old 02-20-2009 | 09:35 PM
bugattitech's Avatar
bugattitech is infamous around these parts
use a wax crayon and mark the wheel and tire then drive it most slip a little. So I would wait a short period of time before beating on it.
Old 02-20-2009 | 09:49 PM
DFW911T's Avatar
I waited 23 hours and then made those tires wail!
More wailing tomorrow at the drag strip.
No audience to egg on the installer, he was really serious.
Thanks, good tip on the crayon for tomorrow.
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
There are some guys who will over use the lube to make it easy to slip the tire on. In that case, your Black series may cause the rears to slip a little and break loose. Most guys I know will put on a minimal amount of lube just to avoid that exact issue with high hp/torque cars. Bugattitech has the right idea. Mark the wheel and tire somehow just to make sure.
Old 02-28-2009 | 08:22 AM
Gofishracing's Avatar
Gofishracing is infamous around these parts
your shop can use extra hold hairspray as a lube- like the bikers do- then you won't get any slippage !! I use to need to mount my tires on 930 that way-
Old 02-28-2009 | 09:48 AM
damon@tirerack's Avatar
Moderator
It is possible to slip a tire on the rim with too much lube. I have seen people slip wheels as much as 15% by getting on the car too hard right after they are installed. Take it easy on them the day you put them on and they should be fine the next day.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
04-28-2022 01:38 AM
The_Ruski_Driver
10-25-2015 09:40 PM
RallyBird
10-07-2015 02:20 PM
horsepowerfarm
09-10-2015 07:09 PM
FIRST_PORSCHE
08-30-2015 12:00 PM
