are these rims safe for the weight of cayenne
cayenne weight is 4969 lbs----rims have a load rating for 2100 lbs each---will these rims be ok for the weight or should i get rims with a higher weight rating-----i thank you for your replies and recommendations---have a great day
Should be okay
I can't tell which wheels you're talking about but if the load rating is honest, then it is about 950kg which is appropriate for an SUV like a Cayenne. Make sure they're a good brand you can trust.
HotRod
09-10-2015 07:17 PM
manfred@loma_wheels
09-02-2015 11:22 AM
