Wheel Adapters
Wheel Adapters
I have 2010 Cadillac CTS as my daily driver which has a bolt pattern of 5x120. I have multiple sets of wheels (it just happened somehow ), factory, 22inch GFG. I have been searching for adapters that convert my 5x120 bolt pattern to 5x130 because I have a set of 19inch iforged that came off my old 911 that I want try out. My search results have come up empty handed so far and Im beginning to think that the conversion isnt likely.
All input is helpful!!
OK, I'll break the ice, you should first understand that in using adapters you'll be pushing the wheels out by at least 25.4mm which will create a lower off-set by this amount. If you're off-set is fine with that min difference then you are set to go.
We have built spacer kits for customers in the past for custom situations.
-Eli
-Eli
I ordered custom hub centric adapters from motorsport-tech.com that I used with a set of BBS CH's that I had widened to 19x12's from them as well. I had 0 vibrating issues with their adapters and they can build them as thin as 15mm's, all hardware included
PorscheEnthusiast
11-13-2015 02:23 PM
09-01-2015 03:16 PM
