Hunter wheel balancing equipment
Yes. The GSP9700 and a good tech can balance most bad wheelsets down to the point the wheel won't shake. It's all we use here. Check out www.gsp9700.com for more details.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
I think it's up to whoever does the balancing job. I had a set of wheel/tires balanced with Hunter Roadforce and it vibrated over 80mph, whereas the same set balanced with a Coats old school machine did not vibrate at all upto 150+mph.
If you spend the money to have your wheels road-forced, INSIST that the best guy they have do it.
Machine quality means nothing if the user is untrained/inexperienced.
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
04-28-2022 12:38 AM
